09.10.2008, 04:12 PM
Originally Posted by lind5 View Post
well i do have a gorilla max revo conersion that i run a mamba max on 4s with a f/7xl i suppose i could put the 1515/1.5d motor in that truck i may need to get a mamba monster for that though
i will look into geting the 1y or the 2.5d ill see if mike has any in stock
cheers for the advice buddy............................................. ....................
The MM should be ok with the 1.5d. Just run an external ubec and a fan on the esc. Maybe add another capacitor. It will pull about the same amps as the 7xl. Plus the neu will be more effecient, and use lower gearing than the 7xl for the same speed, the neu has a higher kv, 2700 vs 2300 on the 7xl. It may even pull less than the 7xl, maybe?!!?
