jayjay283
jayjay283's Avatar
09.10.2008, 05:12 PM
I didnt have good luck with the MM and 1.5d, I used a MM/1Y in my 10lb 8T and temps were always 140 maximum on MM 135 on 1y geared 17/48. The 1.5d made the MM go to 175 after 7-10 minutes of running then I would stop as I didnt want to melt it, temps of 1.5d were 150. I used a 25mm fan on the MM and a bec, no caps. Ive heard of guys drilling holes in the MM case and using a fan on the side aswell. I just gave up and waited for MMM, figured the amps were just too high in that setup
