Originally Posted by MetalMan
Do you have another motor to try? That can tell you if it's the motor or ESC. Have you tried wiggling around the wires between the MMM and motor?
No, I don't have an extra motor but I may very soon, was thinking to get a better one anyway. I have wiggled all the wires and done a good inspection of them and don't see an issue. I did use CC 5.5mm bullet's on the motor connection between the motor and esc, should they go?
Originally Posted by Arct1k
Check your motor leads but the abrupt stop may have damaged the rotor - you may have to open it up to have a look the magnet alignment...
Hope I don't have to do this as I don't even know where to start.
Originally Posted by JaySki
Gonna likely be a bad solder joint.. I had the EXACT same issue.
Check your Motor Connectors and re solder.
Did your car/truck run perfect for a while then suddenly start to act up? This is what happened to me.
Thanks for the heads-up!
Sorry for the dupe, I put this question in the wrong section the first time.
