TruckBasher
TruckBasher's Avatar
09.10.2008, 06:50 PM
Well, I do hope you also take into consideration that most of the setup that people had are working ones and even work on your under rated 3S Mamba max controller. And works great on other controllers even the cheapo ones.
I think its a big mistake to look into wonder around peoples setup for this failure. Well it will help at first to isolate any problem but you said it your self. There is no common setup that fails and irregardless of External and Internal BEC it still fails. Which means setup is not the cause, and the only common factor is the MMM itself.
Not that I hate CC, I still use your products and I love MM. But I also want MMM to work so lets face the facts. The failure rate is small at this point and that only those guys that complains are joining the forum to tell about the MMM tail. But let us not forget that most of the CC MMM are also on the shelves, RCM/Impack/Tower and even Ebay now are stacking up with MMM so the actual figure that you manufactured is not the total number of MMM to compare the failure...rates will be higher....
I honestly hope you figure this thing out so I can use the MMM....ohh and BTW I am one of the ones that modded my MMM which lasted longer that the stock MMM....it died now but I enjoyed it...sad that its not on warranty but its ok...I can even donate it to you so you can check it....
E-Slayer direct drive to diff
