Originally Posted by Darion
Got my MMM hooked up today with no issues from the ESC. Did have a soldering issue but thats on me. I am running a FLM converted Savage, locked into second gear with no mech brake or reverse module. I am running my MMM as is out of the box, bec and all, with the lipo setting on auto. I have run five 2s 25c 5000 packs through it, just taking it slow before going up to 4s. Temps are good on everything run time was about 15~20 minutes going through an 8xl motor. I'll get to running 4s through it in the next few days but for now all is good.
Darion
Be careful going up to 4s.
If you sift through the information provided on the "Monster Max Data Collection" thread you will see that all of the setups that have failed (including mine) have all been 4S or higher. Seems like the onboard BEC (and a lot of the CC UBEC's) just can't hack the increase in voltage.
What would be great is if you put a couple of more Hrs. on your 2S setup and see if it still runs. Then if your brave enough give it a go on 4S-6S.
Just an observation
