Originally Posted by SpEEdyBL
You are going to need more than 5000 mah 25c batteries if a 1.5 turn hv motor is going to be any use at all. I would recommend at least two of those in parallel. My hv 4.5 already taxed my maxamps 5000 mah batteries and a I imagine a 1.5 turn would have the capability of drawing three or four times as much current even with only 2s, compared to a 4.5 turn on 4s.
Maxamps don't count in my (and many other's) book and all and I mean all Maxamps don't even come close to what they're rated for. My packs have seen upwards of 180A+, I will also have 30C and 35C packs on the way and it should be fine. Most of the higher quality cells that I use are good for bursts of over 200A and for the few seconds that will only be needed for the speed runs everything will be fine.
