spaz163
Functionality with a dash of Form
spaz163's Avatar
09.13.2008, 03:53 PM
The cheap BECs and the CCBEC did have some noise on the power line during my tests. The DE BEC I tested had none (it was the small one though), so I imagine it's bigger brother would be similar in performance.
A couple things to try is to add a small 1000uF (or higher) 16v capacitor on your unused receiver slot. Also wrapping a turn of the throttle cable through a ferrite donut ring may help too. Your low-level wiring looks well isolated from the high current ones, so that should be fine.
Brian thanks for the post, I did read your review of the ParkBEC, everything sounded good. I have read good things about the SportBEC and that is the reason that I went with it.
I have read posts on here where someone else was fighting glitching with a CC BEC and they tried the cap and ferite ring but it did not help. I am hoping that this DE BEC will not cause problems. I ran this same setup with a Rx pack for several months with zero issues. I just wanted to lighten the load by going with a UBEC.
