DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.14.2008, 02:39 AM
Right-o, thanks for your help. Ill make a few changes. I'll put 40wt in the front (keep the 55 piston in for now) and put 35wt in the rear. Will move the camber link to #4 in the rear and will check what the camber is on both front and rear. Hopefully my ride height gauge isn't to far away. Will also change to 3000wt diff fluid as most Losi 8ight Brushless owners run 3000 in the rear.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
