Raze ST Truggy
09.14.2008, 07:15 AM
I've reead the reviews on the HC chargers, and so I use a multimeter to check the individual cells regularly also. Here is the charger that I have:
http://www.hobbycity.com/hobbycity/s...idProduct=5606
and it's specs:
Spec.
Operating voltage range: 10.0~18.0Volt
Circuit power: max. 150W
Charge current range: 0.1~7.0A
Discharge current range: 0.1~5.0A
Current drain for balancing Li-Po: 300mAh/cell
NiCd/NiMH battery cell count: 1~27 cells
Lithium bettery cell count: 1~8 Series
Pb battery voltage: 2 to 36V
Weight: 574g
Dimensions: 170X110X35mm
Can it not even put out the 150W that it is rated for? I should also note that when ballance charging the pack the charger would always charge the cells to 4.25v each. I do like the hyperion chargers, so maybe I'll look into one of those at some point.
-Brian
