Ok guys yet another new plan/idea.... I ditched the tranny and will be going directly off the center diff. But heres the catch. I will not be running a setup you guys are thinking of with a pinion meshing with the diff gear. I removed the diff gear completly. I will be running chain drive. I will purchase both the pinion sproket gear and the center diff sproket gear here-
http://www.electricscooterparts.com/sprockets.html I will be buying a 11t #25 chain 8mm bore and a 14t #25 chain 8mm bore sproket.
Also here is the final specs of this setup...
I also found some really cheap wire "10awg-8awg" for this project-
http://www.electricscooterparts.com/wire.html
