MetalMan
MetalMan's Avatar
09.14.2008, 02:29 PM
Originally Posted by wade7575 View Post
It won't matter wether you run it on 4S 5S or 6S the MMM will olny supply 5.5 volt's to the RX I have seen some people posting on this site saying that with the new MMM V2'S there getting 6 volt's oing to the RX.Most RX'S are ment to be run on 4.8 or 6 volt's so if you ran your MMM on 4S like you said you did and it was putting 14.4 volt's into the RX it would have fried your RX long ago,it would have been up in smoke as soon as the switch on the MMM was thrown.
He's referring to the voltage sensing channel on the Nomadio transceiver, which can be used to monitor the full battery voltage, so that alerts can be set.
If the manual says 20v is the max more probably wouldn't hurt, it probably just wouldn't display it.
