09.15.2008, 02:46 PM
Originally Posted by bruce750i View Post
Those are good suggestions, also might try a little wet paint drops on top of body post then push your new body onto the wet paint leaving transfer marks in the body, then clean paint off body post. Drill small holes at first to check to see if you like where they are.
This is usually what I do and it works well. Except I use a sharpie...
I've also added a tiny piece of tape to the top of the posts. Because the post tops are rounded, the tape sticks to the body when you pull it off again. Same idea as the paint/marker idea...
