crazyjr
crazyjr's Avatar
09.15.2008, 06:52 PM
Originally Posted by MetalMan View Post
He's referring to the voltage sensing channel on the Nomadio transceiver, which can be used to monitor the full battery voltage, so that alerts can be set.
If the manual says 20v is the max more probably wouldn't hurt, it probably just wouldn't display it.
I couldn't find the thread, but the head at Nomadio, At least the head of the support forum said anything over 21v will burn the tranciever. So nothing over 5s lipo if you run the telementry
