09.15.2008, 08:54 PM
I can understand where Patrick is coming from! I know and understand that this is just a hobby and have tried to get that through some others heads on here that have been bashing CC because of the problems with the MMM. My v1 died and I patientlly waited for my replacement. My failure wasn't the BEC either as the servos still worked. I honestly beleive it was the Feigao motor that took it out. I ordered a Tekno Neu 1515 2.5d to run when I received my replacement. So far after a few hours of running on 4s with this motor I've had no problems and the MMM hasn't reached 130*F yet. I will continue to use my MM and MMM and supprort CC and let others know that I feel this way. I really hope that this doesn't lead to CC leaving the forum as MaxAmps did. I honestly wish they where still on here. Although they get bashed all the time on here I still use my (4) 2s 6000mah packs with success, yes they get warm in the E-REVO, but I'm sure if they had better airflow over them they'd do better. I have enjoyed the posts Patrick has made, esspecially when he went through the manufacturing process step by step telling us exactly what machines where used.
Patrick - I will continue to use and support your products with or without you here, however losing you would be a huge loss to the majority of the forum that appreciates what you have done!!!
