JThiessen
JThiessen's Avatar
09.16.2008, 09:40 AM
I wish you luck moving a MT @ 40MPH on 3s without overheating! At the very least your putting a huge strain on the batteries, lots of amps at 11.1V. Second all those amps are going to heat up the esc. Lastly the motor is going to have to be a high KV to spin fast enough on 3s to get you to that speed which means more heat, higher kv means more amps! Moster trucks, even a plastic based 3905 Maxx is still a bit heavy to run anything less than 4s.....just my opinion and $0.02
I dont believe that to be true. I consistently ran my 10L using six cell nimh's (3300's and 4200's) in 40mph range without overheating. Done the same with the HV-Maxx 4.5's.
