xcntrk
xcntrk's Avatar
09.17.2008, 09:49 AM
So I have some suspension parts coming; different weight springs (softer in front, heavier in rear), sway-bar kit, and some buggy tires/wheels. I already have some 17mm adapters but they’re not extended. I wouldn’t mind lowering it too. I guess I could use some old rod & ball-ends I have kicking around to test and change the lengths of the pushrods.
any chance you could get a pic of how you attached the side nerf gaurd to the battery tray area? Maybe a shot of the underside of the truck on the battery side?
It’s the stock nerf-bar that I cut down & notched to mate with the tray, then just super glued. It’s temporary as I ordered a replacement set of nerf-bars and plan to use the left-side bar on the batt-tray side. The left-bar has the forward mounting position, and a rear eyelet mount that you can simply run a bolt/nut through the batt-tray to secure. They’re a whopping $4 bucks for the set.
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
