jhautz
jhautz's Avatar
09.17.2008, 11:36 AM
To answer the dif oils questions:
EFFECTS OF DIFFERENTIAL OIL REPLACEMENTFront
Thinner
• Increases steering into corners (off-power)
• If oil is too thin the steering may become inconsistent, especially it can lose forward traction (and steering) during acceleration out of corners
Thicker
• Increases stability into corners during braking
• Increases steering on-power at corner exit
Center
Thinner
• Front wheels unload more during acceleration
• Decreases on-power steering (reduces oversteer)
• Easier to drive on rough tracks
• If a high-power engine is used you could waste too much power and sometime “cook” the oil in the center differential because it “overloads”
• More off-power steering
Thicker
• More all-wheel drive effect
• Better acceleration
• Increases on-power steering (reduces understeer)
• Better suited on high-bite, smooth tracks
• Car can be more nervous to drive especially if a high power engine is used - you might need to be smooth on the throttle
Rear
Thinner
• Increases cornering traction
Thicker
• Decreases rear traction while cornering
• Reduces wheelspin
to make it...
or break it...
Silent...But Deadly
