jhautz
jhautz's Avatar
09.17.2008, 08:35 PM
It will always vary a bit from setup to setup and charger to charger. What you have the LVC set at will effect how much you can put back into the pack. A conservative (high) LVC setting will prevent getting the last drop out of your pack, but it will also help the pack last longer. Most damage is done to lipos in the last minute of discharge right before it dumps and it has a harder time holding voltage. I try and observe the rule of I dont want to run more than 85% of the juice out of my packs. I set the LVC a bit higher so when I hit the LVC on a 5000mah pack I would want to see the charger put back only around 4250mah or so and a 4350 pack only takes back 3700mah or so to keep it safe and make them last. Usually I find that the resting voltage is somewhere around 3.5v when they are at 85% discharged. Of course that will vary from cell type to cell type.
Being conservative with your LVC settings will help make your lipo investment last much longer and the minute or 2 you give up on runtime is worth it IMO.
Also, if it is a damaged lipo or old it will have less capacity than when it was new.
to make it...
or break it...
Silent...But Deadly
