09.18.2008, 10:00 AM
Originally Posted by sjcrss View Post
wow.....thats alot of jing.......but if it's stronger than the traxxas one...then it may be worth it.....here is an option possibly, just sell the modded shafts & gear & adapter plate...and the consumer can buy the cup & internals....might help keep the cost down a few....however, like you mentioned before...i think....one possibility is having them prepaid ( pre-order) the kits and then you produce them......
I thought about doing this. It will knock off about 20-25 bucks. Best thing I have found is to buy a hyper diff from ebay. Seems cheaper than buying parts, and you will end up with a spare spur or crown gear, and the stock outdrives.
If I sold the conversion parts they would be the adapter, modded lower gear, modded output shafts, spacer, screws, and shims. I am looking to do some of the simple work myself, to keep the costs down. I f this is really popular, I may have to find someone locally with a cnc and have them make a batch. It is not a very complicated design, trying to keep it as simple as possible.
