DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.19.2008, 01:48 AM
Well did some changes. I adjusted the front height to 27mm (was around 22mm) and set camber to -1, rear set to 28mm and camber -1.5. Ride Height must of changed due to weight battery tray/battery etc. I also moved the rear camber link to 4.
It looked like raining so i decided just to take it for a quick rain out on the street. Went to took off and straight back on the rear wheels scrapping the wing. So I changed the rear camber link back to 1 and it still did it so I put 35wt oil in the rear shocks and it still does it. The front end really lifts up when I accelerate. Should I lower the front ride height?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
