Originally Posted by George16
I believe the nitro revo cd tooth count is 28T while the erevo/3905 emaxx is 33T.
Check this site Linc. They sell composite gears.
https://sdp-si.com/eStore/
Go under "Gears" and then click on the "Composite Material, "Spur Gear".
Do I get a discount if you find what you need from this site    ?
You are in the std section, not metric. No mod1 33t plastic gears on sdp-si, already checked. I can give you the 1% trying-kinda-hard discount!!!!
You are correct with the revo and erevo tooth counts...
