09.20.2008, 07:03 AM
Thanks for the advice guys. I'm going to get the medusa 3300kv and run it on 3-5 cells. What would you guy's sugegst for gearing? 3.17mm shaft or 5mm shart and convert to a revo sper/ slipper setup.
Right now I've got a stock Rustler trans case with a metal idler gear that seems to be holding togeather okay. Already ate the diff gear once, but am going to the steelringed version next time. Should I upgrade to the FLM aluminum trans case? thanks
-Brian
