jhautz
jhautz's Avatar
09.20.2008, 10:02 AM
Originally Posted by MetalMan View Post
Looks very nice indeed! Jeff, can you tell if the mount is spaced such that you could fit mechanical brakes without a spacer (when using smaller pinions)?
No. You would still need the motor spacer if you want to run small pinions with the mechanical brake disks. Its no different from any of the other motor mounts in that regard. But the spacer Mike sells works perfectly. I have been running it for a long time on my truggy and its perfect.
to make it...
or break it...
Silent...But Deadly
