09.21.2008, 05:03 PM
Noooooooooooooooo! to the maxamps. There are so many better options, take a look around and see what the pros use (thats the guys on this forum ). I would suggest anything from rclipos.com basically.
RPMs are determined by motor kv (rpms per volt rating) and input voltage; gearing only alters wheel rpms. if you use a higher voltage with the same motor, you must gear down in order to reduce the load on the motor, and therefore maintain the same overall speed- efficiency will increase usually, and temps will decrease (longer runtime is also possible usually).
