Originally Posted by DRIFT_BUGGY
Would it be possible just to put 4 little round foam (or whatever them are) things inside the bottom of the case? 1 at each corner to stop the bottom from hitting or will that make the fan sit up more?
Ill try to find what I am talking about and post it up
Some o-rings or grummets should work as well as rubber, plastic or Teflon washers. I got a Monster Max coming and I'm going to look at everything possible to have it running good. I'm not going to use the BEC as I like my Rx pack too much
