Thread: MMM Mods
09.22.2008, 02:12 AM
Originally Posted by CRTIM View Post
would it be possible to build up those 4 corners up with something (glueing some plastic or even hot glue ) so the board would sit up further and not wobble ?? and would the case still fit ??...or is it just as easy to cut out the bottom of the case ...thanks for the help
I just clearanced the bottom of the case so that the plug would not touch it. Then I made some foam "suspension" pieces for the pcb and put it under the larger wire solder points. So far the fan still works, so I guess the plug is stll intact... I need to pull the esc back out and see how the fan wire is doing. I wonder if it has frayed yet, as it sits between the pcb and the case...
