Originally Posted by FG101C
Shows out of stock on the Lightning mount. Is it possible something else has the same dimensions? The Kyosho looks identical to the Lightning if the pictures are accurate. Also looks the same as the CEN mount. What about using the Tekno motor mount? Not sure how that one mounts to the chassis, holes look square in the pictures.
For the other RCM mounts you will have to contact Mike .
The Tekno mount you can use as it's universal , i used one in my X2 before going to Mikes mount .
Problem is you will have to drill and countersink four new holes in the chassis to mount it and allow room for gear mesh no biggy i did it , secondly you will have to make up a diff brace to support the center diff since the Tekno mount is seperate from the diff .
If you don't do this when the chassis flexes it will change your mesh and ruin your gears.
Best to contact Mike and order the RCM mount and stock lightning stadium center diff mounts
