Thread: MMM Mods
Sneaky Pete
09.22.2008, 10:17 PM
Originally Posted by RBMike View Post
The MMM(v2) that I have with the most hours on it now (of all MMM's I've had) is the one that the fan connector broke off of on the first day I ran it. I took this one home after it broke, removed the fan & broken off connector and replaced the fan with one that plugs into the RX. This one is holding up great. I'm starting to think the the fan connector getting banged on the case & into the brain board may be what is causing the BEC to fail.
Hey Mike, we were discussing this on Sunday at Bayside, but later last night I was thinking about this...allegedly, there are alot of burnt V2's from right when guys are calibrating or RIGHT when they start running them (slow). That is, they wouldn't have caused any jarring to make the PCB flex causing a broken solder. So, while I do think the plug is a problem, and has perhaps caused problems, there must be another possible cause in addition.
