Originally Posted by Sneaky Pete
Hey Mike, we were discussing this on Sunday at Bayside, but later last night I was thinking about this...allegedly, there are alot of burnt V2's from right when guys are calibrating or RIGHT when they start running them (slow). That is, they wouldn't have caused any jarring to make the PCB flex causing a broken solder. So, while I do think the plug is a problem, and has perhaps caused problems, there must be another possible cause in addition.
Ya Pete, I agree. There is at least 1 more problem that is NOT related to the fan clearance/fan wires/fan connector mechanical problem. Another issue I could see causing problems is the heat sink being to close to the 6.5mm sockets. On one of the Monsters I have the heat sink is so close to the battery sockets that I could barely get a peice of electrical tape between them.
