rchippie
rchippie's Avatar
09.23.2008, 01:46 PM
A smaller spur, or larger pinion will increase top speed. A smallre pinion or larger spur will decrease top speed and increase torque via gear multiplication.
On a side note, I always think it is best to use the smallest spur and largest pinion to achieve the correct ratio. That way you will see less pinion wear, and the gear mesh is greater at any point due to better engagement of the teeth. Anyone who has run a very small pinion with a large spur can attest to the fact that is does not feel as smooth as a larger pinion with a smaller spur.
This mainly applies when you have different diff and tranny ratios to choose from. I noticed it quite a bit when I put my slayer together. Because I am using a revo tranny, which has more reduction than the slayer tranny, I had to run a much larger pinion. I currently have a 20t pinion with a 36t spur, and it runs very smooth and can be set up with very little backlash in the gears.
What i did'nt know was if the torque or top end was affected if a larger spur & small pinion were resversed & it was a larger pinion & smaller spur . But bill at associated jsut told me if the ratio is the same it doe's not matter if it's a large spur & small pinion or the other way around . Also im talking about 48p gear in my tc4 .
REAL MEN RUN BRUSHLESS
