What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.23.2008, 10:57 PM
The motor on the right seems to use a slightly smaller radius for the screw pattern. I'm just eyeing it. If the motor on the left has a 25mm radius then the other appears to be less than 24mm. Does it have two different radii? 25mm and another? I'm sure Neu wouldn't mind replacing the endbell for you if need be.
