George16
Supermaxx
George16's Avatar
09.24.2008, 11:19 AM
The UE 7.5 diff outputs will still be short for what you're planning to do. I had tried that route before. I had better luck using my home made diff outputs like what Mike sells. I made mine from revo stub axles (I cut off the threaded portion).
My recommendation for you is to buy another set of drive cups and use them with the diff outputs you bought from Mike. You can try UE's 6mm drive cup. It measures 19.7mm from end to end ( I have a bunch of them). They are made from hardened steel and should last you long.
If you can wait for a day or two (it's midnight here now), I can take measurements of my UE 7.5 diff outputs using my digital caliper. Let me know.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
