One of my Bday gift got here and somewhat modded
lutach
lutach's Avatar
One of my Bday gift got here and somewhat modded - 09.24.2008, 12:00 PM
Just got my Mamba Monster today and did my little MOD. Nothing special, but I'll let you guys see what I did. I noticed that the phase plugs seems to be touching the heat sink, so it might get shorted unless the space is so small that my 30yr old eyes can't see. I removed a little of the plastic off the bottom of the case just bellow the fan connector. The connector is actually 1mm or so too tall and after I did it the PCB sits flat on the bottom of the case. I added some foam to the bottom just to eliminate any more movement. The top case had a problem and you can see I removed some plastic to allow the male plug to go in with no issues. I will run the ESC in my BPP with 5S and 6S powering a Neu 1521/1Y with 20T/65T gearing. I will also be running the old version of my 6S ESC Here are the pictures:
