Originally Posted by Sammus
Could be a solder connection on the motor side...maybe? Like if something came loose then that third pole wouldnt be energized and it would kinda be trying to keep the rotor locked in one position. then if the joint was bumped back into place it would function normally again...
not likely, but worth checking i think
Yes or it's shorting out with the heat sink. Mine seems to have all the three phase plugs contacting the heat sink.
