crazyjr
crazyjr's Avatar
11.01.2005, 08:23 AM
Well, on nitros if a screw is loose or a throttle or brake rod rubs against metal, it can cause interference, but without the carsitting in front of me it is hard to tell. I know that in some cases, it was the brushless system that was the causeand the reciever needed to be moved about 3" away from the system, but you have that covered. Are you running AM or FM?
