09.25.2008, 11:23 PM
What really needs to be developed is a good way to mount a MMM in place of an evx-2 esc on the E-REVO and E-MAXX trucks. Joelling, I think, had a nice design but something needs to be readily available or at least can be made if asked for one. I for one would def buy one if it is well designed.
I already did this on my Erevo. Pretty simple. I took a piece of kydex (any plastic over 1/8" thick should do) and cut a square out that was wide enough to fit over the little pad and screw holes that the evx sits on. I then cut a channel in the foam that is stuck to the chassis. I made the channel run front to back, and left it wide enough to get a decent sized zip tie in it. Then I screwed the plate over it with some small button head m3 screws. Used some servo tape to stick the MMM to the plate, and then ziptied over the top of the MMM to hold it tight. It has some cushoin afforded by the foam and servo tape, and the zip tie keeps it in place. If you use the correct holes on the erevo chassis you can get the screws out without removing the esc. I could whip up a few plates and a picture manual, but it is pretty easy to do...
