11.01.2005, 04:09 PM
Hi Papa!
The red is for programming, i attached the manual, you might find some helpfull use.
The motor you are using takes plugs, The motor can be used in different configurations. can't find the appropriate documentation at this moment. the wire can be covered with shrink, or can be replaced. (mike could do this, i pressume) covering it with shrink would work..
