ANGRY-ALIEN
ANGRY-ALIEN's Avatar
09.27.2008, 12:15 PM
The UE 7.5 diff outputs will still be short for what you're planning to do. I had tried that route before. I had better luck using my home made diff outputs like what Mike sells. I made mine from revo stub axles (I cut off the threaded portion).
My recommendation for you is to buy another set of drive cups and use them with the diff outputs you bought from Mike. You can try UE's 6mm drive cup. It measures 19.7mm from end to end ( I have a bunch of them). They are made from hardened steel and should last you long.
If you can wait for a day or two (it's midnight here now), I can take measurements of my UE 7.5 diff outputs using my digital caliper. Let me know.
Hey George, thanks for the advice man... I have tried those OUTPUT SHAFTS from Mike before along with the MIP cups and this is what they look like now: http://picasaweb.google.com/khfranci...26057184813890
I am not sure if the shafts extended far enough out the diff case for the mip cups to get enough surface area to hold on.. I am willing to try the shafts again if they'll work with the cups from UE...
If you have a enough to send four, PM me with a costing (still can't make the buy from the UE site)
Did you use GRUBS or SCREW PINS to hold the cups to the shafts?
Alien
