09.28.2008, 03:42 PM
Alright, lets figure it out!
What kind of offset are you wanting to run on the rims? Zero right?
I can order some hubs (You want some also? I can get them alot cheaper then you can anywhere. PM Me if so)
And then we just need something to make up the dia difference. Im pretty sure the stock out put is 5mm (can you confirm this? I dont have calipers on hand) to 8mm. Would be cheap and simple enough to have Mike make us. And then bolt them up and go
I can get some Kyosho hubs, which are 12mm offset (or 1/2 in) So that would be plenty wide IMO, or we can do something like the RC8T ones, or some other brand, that has 3/4in off set, So we can have the car overall 1 in wider, or 1 1/2 wider. Either way works for me, Id probably pick the 3/4in ones my self, but what do you want?
We can do this for sure. Then once its all done, RCM Mike can sell them in his store, im sure were not the only ones that want this set up
This would be the equivalent to LPR's on the full size truggy, but here we use normal size truggy rims, with 2.2 truck tire stretched over them (and yes it looks, and works AWESOME! )
