Thread: Good 3s lipo?
trev3813
Dsm needed
trev3813's Avatar
09.28.2008, 03:44 PM
Originally Posted by azjc View Post
that charger will only charge @ 3 amps, and I am assumming you will be using a 5000 pack in a Rustler ....it would be a long charge with that charger. I would get at least the 0606i which is a 6 amp charger and I always look ahead when buying a charger, always buy more charger than you think you need. and as far as a pack I would go with a Zippy "R" or True RC...I have a 4s 5000 True RC pack that was a little to wide for a Rustler batter tray I tried dremeling out the tray and after going through a number of bits I finally drilled a few holes in the bottom of the tray and layed the battery on its side and secured with zip ties
Thanks for the advice
0606i This one correct?
I will be running this battery http://www.amainhobbies.com/product_...d/25014....The
