brushlessboy16
brushlessboy16's Avatar
09.28.2008, 11:49 PM
1/8 al is a bit thin. Go up to 1/4 or 5-6mm. Then you can drill and tap the edges. Kydex makes great trays. I like to use the velcro strap and cut slots in the sides to thread it thru.
The only reason i said 1/8 is because i have it right here, ill try and get thicker stuff.. if no will just drilling through and using a nut work?
how would i bond the corners of te kydex?
