09.29.2008, 12:13 AM
The only reason i said 1/8 is because i have it right here, ill try and get thicker stuff.. if no will just drilling through and using a nut work?
how would i bond the corners of te kydex?
I usually heat it and bend it, then just let it go. It is stiff enough not to need the corners or edges to be attached. I do use the velcro strap to hold the battery to the tray well, basically wrapped all the way arounf the tray and the pack. Never lost a pack, and I bash hard.
Not knowing your design, I cannot really comment on material thickness. Sketch it out and I will take a look. You cannot drill/tap the edge of 1/8 al easily and it will not be that strong.
