TruckBasher
TruckBasher's Avatar
10.01.2008, 09:26 AM
I have a G2 EMAXX, MMM with Tekno neu 1515/2.5d 6S2P A1232 EMAXX/V2 Sliperrential/Big joe and Save X tires (almost the same diameter)...13lbs truck
Temps for multiple run
Motor: 120-140*F(Max temp)
MMM: 110-120*F
Battery: 80-100*F
last time I've had a high motor temp was the screw on the slipperential gear came a bit loose another one was when the Spur slipper clutch was loose....but once they got tightened I never reached higher temps than posted above
E-Slayer direct drive to diff
