10.01.2008, 06:07 PM
Yep - Instructions were posted further up - I like fire!
You can make you own smokers by mixing sugar and salt in the appropriate quantities with water, then leaving it to dry in whatever shaped vessel you require. You could have a smoker that easily lasted 5minutes+...
Smoke...
Ignition is the only issue... But not sure why you couldn't use an electric igniter...
http://chemistry.about.com/od/demons.../smokebomb.htm
