david lamontagn
10.03.2008, 10:08 AM
Yes my Thunder Power 5000mAh pack is rated 25C and and can put out 125A continous.
This is for the run time, i think that my runtime will be cut by a good 7-8 minutes compared to my Feigao 10L.
But anyways, i have an eagle tree on order, so i will verify how much amps this motor will pull from my pack, and if my run time is too short, i will use my Neu 1509, 2700Kv to the place of the 1512. Little bit less torque, but longer run time.
And the 1512 will be for sale here
Thank you!
