10.03.2008, 10:50 PM
I will be using a 4-shoe 1/8 clutch and cb setup when I get mine.
You might want to give the setup that is already on the adapter a try first. It is the stock shoes and a spring that seemed to engage just right. I never had it slip, and broke it in correctly, so it does not get too hot. I prefer a pinion myself, but the tekno mount can be moved closer to the spur with some spacers behind it and some longer screws.
