making my 9v dremel into AC powerd
t-maxxracer32
t-maxxracer32's Avatar
making my 9v dremel into AC powerd - 10.04.2008, 04:28 PM
hey guys i have one of the cheaper chicago brand dremels and the thing is great! it has a bunch of pieces that make any job possible.
one problem.
at 9.6volts the thing is pretty weak.... there is no way i could dremel a motor shaft or really anything that is tough...
i was just wondering how difficult it would be to hook it up to the AC power of my house.
i still do not understand why things cannot just be plugged into the wall and call it good but i would like to figure it out.
here are some questions i have..........
-my hyperion 1210i needs a power supply to make it work. i realize it runs off 12v so what does the power supply do with the 120V my AC power puts out?
-if there was a capable esc of holding 120 volts could you run your rc car directly to the AC with an extension cord? i realize this is pointless but i am just wondering. or would it pushing too many amps?
-the old style 15min chargers do not need a power supply... what do they have inside them that alows the use of AC power?
-if i got one of those ac adaptors that allows you to select the output 3.3v 5v 12v would that work for the hyperion instead of needing a massive power supply? since it would only be pushing out 12v?
-last! how do i get my dremel to run off AC power? so it will have more power!
thanks for any help guys.
also... i am searching google for all these answers but have not come up with anything yet... hopefully i can learn a little basic electrics through this thread.
