t-maxxracer32
t-maxxracer32's Avatar
10.04.2008, 05:35 PM
Originally Posted by TDC57 View Post
Thanks for the comments guys..
I’ve got questions paintball questions
• Can you please look at these shoots and then try your best to answer the following questions:
• Will this bottle setup work ??, I basically removed everything down to as far as it goes and I'm doing a direct connect now.
If that workedi would be very suprised. you have no regulator for the co2 tank so there will be WAY too much pressure for those poor hoses.
• Do I need to worry about any air reducers, diaphragm or what not’s ??
Im guessing you mean regulator? ya you will definetly need one of these to make the gun be able to hold all the pressure from the co2.
• Where can I buy this small black house ?? if I extend it will have a negative effect one the gun ??
here is a link to the solenoid hoses http://www.paintballgateway.com/wgpaupnho.html extending it should not effect it too much but again.... i am almost positive you will need the regulator that game with the gun
• I'm thinking about just permanently locking the trigger switch on the main circuit board and running the it’s power supply to my 3rd channel on my RX (that way in theory) I just need to hit my 3rd switch and it goes live and starts shooting (???)
this could work the problem is that when you hold down the trigger while turning on power to the gun it will go into programming mode.. so it will not shoot. maybe you could get a servo attach a horn to it and just turn the servo causing the horn to hit the trigger when you want it to shoot
• let’s talk hopers shall we.. Do I want to use just a gravity feed one or the one I have ?
since you already bought an electric one i dont see a reason to get a gravity feed. they are basically the same size. you could go with something smaller such as this http://www.paintballgateway.com/50ropohocl.html
• I’ve gone to several paint stores but I couldn’t find a smaller one (is there on
• out that holds like 50-75 shoots in lue of 200 ??
above link
• will my 9mm bottle get things cold with this setup (?) if so what insulation should I use to protect what little hose I have
i honestly dont think it will work the way you have it. turn the gun on. if the hoses do not blow immediatly i will be very very suprised. even if they do not blow then... i am sure it will blow after a couple shots. these guns are meant to run at around 250 psi and without a regulator you will be well over the limit. you could buy a low pressure compressed air tank but these are much larger and much more expensive
http://www.paintballgateway.com/dxscoairtasy.html
• Any ideas on what to use the cover / protect the curict board, you’ll notice that I have elevated above the Truggy drivetrain so I'm good there but I need to cover / protect the boards from dirt and bashing..
electrical tape? you wont be launching this thing or bashing it crazy while the gun is attached im guessing?
More questions to come.. Thanks in advance for your time..
Shaun.
hopefully some of these answers are what your looking for!
