10.06.2008, 03:43 PM
Yes, each wire.
Actually, disconnect the motor from the ESC first. Test continuity between each motor wire (phase) to the motor case.
But also check the screw length to make sure they aren't touching the coils. I usually just gently screw in long screws by hand until I feel them touch the coils. Then, back them out a couple turns. This is the max length you should use (don't forget to account for the motor mount thickness).
