Sammus
Sammus's Avatar
10.06.2008, 09:19 PM
Cool. Except where does one find a 26t or 33t pinion?
It may be a good idea to add something about the pinion/spur ratio, and that you can also choose a smaller spur and not such an enormous (impossible in this case) leap in pinion size.
I guess this is hardly a gear selection tutorial sheet, but if you say its good to change the gearing if swapping in a lower ratio diff, then recommending a pinion size that's near impossible to get, it may be a good idea to put a word in about it. Or am I being pedantic?
